Double Speed Sensor Split Cable
The Aim EVO4S double speed sensor split cable allows 2 speed sensors to feed into a single input on your EVO4S data logger, with one end using a 712-type male connector and the other end branching into 2 719-type male connectors. The split cable provides a reliable and compact solution for reading front and rear wheel speed (or dual speed sources) through one port on your data logger.
Why Choose the Double Speed Sensor Cable
The Aim EVO4S double speed sensor split cable simplifies wiring by combining 2 speed signals into one logger connection, eliminating the need for extra ports or additional hardware. The cable maintains signal integrity under high-vibration, motorsport environments thanks to its strong build.
Essentially, the EVO4S double speed sensor split cable can be used to expand speed monitoring without complicating wiring.
  • For Aim EVO4S data logger
  • Allows 2 speed inputs
  • 4-pin male 712 Binder
  • Split 4-pin male 719 Binders
SKU: EVO4-SSC-712-719
EVO4S Split Cable Pinout
スピードセンサーテクニカルシート
