Professional Data Logger
Take your data acquisition to the next level with the brand-new Aim EVO6 Data Logger, a professional-grade system built for racers. Absolute precision and total control. Designed for high-performance motorsport applications, the EVO6 delivers advanced data logging, integrated GPS, and inertial tracking in one compact, rugged unit. This isn’t just data; it’s your competitive edge captured in real time.
Why Choose the EVO6 Racing Data Logger
The EVO6 Racing Data Logger is engineered for flexibility and scalability, making it the perfect core of any modern data system. Whether paired with displays, power distribution modules, or additional sensors, the EVO6 integrates seamlessly into your setup. Its ability to synchronise GPS, IMU and vehicle data ensures you get a complete, accurate picture of every lap—helping you analyse performance with confidence and make smarter decisions on track.
If you’re serious about extracting every ounce of performance, the Aim EVO6 Data Logger is the upgrade that puts you ahead. More data, more control, more speed.
EVO6 Features
The EVO6 features 8 fully configurable analogue inputs compatible with a wide range of sensors, including temperature, pressure, and more, along with 4 speed inputs and coil RPM acquisition for precise monitoring of vehicle speed and engine performance. An integrated 25Hz GPS module delivers highly accurate lap timing and track positioning, while the 100Hz 3-axis IMU (±5G) captures acceleration, braking, and cornering forces in detail for deeper insight into vehicle dynamics and driver input.
Built-in Wi-Fi and Bluetooth enable fast, cable-free configuration and data download, while expandable SD card storage of up to 128GB allows longer recording sessions without compromise. All of this is housed within a compact anodised aluminium enclosure designed to withstand the demands of extreme racing environments.
A Range of Data Sources
The EVO6 can sample all the data you need from a wide range of sources, including your vehicle ECU via CAN, RS232 or K-line, as well as from the internal accelerometers and gyro, and the GPS09 receiver included in all available kits. Additional data can also be acquired through analogue and digital inputs, external expansions, and predefined math channels.
Sensors can be connected to 8 configurable analogue channels, the RPM input, and up to 4-wheel speed inputs, making the EVO6 ideal for advanced vehicle data acquisition and analysis.
EVO6 connection ports
Connection Type
The EVO6 features two multi-channel motorsport connectors designed for simple and reliable installation. A high-quality wiring harness manages all connections through a 37-pin connector for main functions such as power, CAN, and the Aim CAN network, along with a 22-pin connector dedicated to additional functions, including CAN2, digital outputs, and more.
Digital & CAN Outputs
The EVO6 Data Logger features two low-side digital outputs (switch to ground), which can be configured to automatically switch external systems on or off based on the value of analogue or digital inputs. This allows automatic control of devices such as additional lights, cooling fans, circulation pumps, and other accessories when specific conditions or events occur.
The EVO6 also includes CAN Output functionality, allowing messages to be sent directly to an existing CAN network to expand vehicle monitoring and control capabilities.
Sensor Compatibility
Sensors can be connected to the EVO6 Data Logger via:
  • 8 analogue channels with configurable inputs or thermocouple inputs, with a max frequency of 1,000Hz each, used to sample data coming from temperature, pressure, suspension and other sensors.
  • 4 speed inputs, which allow you to monitor the different wheels' behaviours.
  • 1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
  • ECU Connection: CAN, RS232 or K-Line to 2,000+ industry leading ECUs
  • External Modules: GPS09, LCU Series, SmartyCam Series
  • Analogue Inputs: 8 fully configurable: 0-5V, 0-12V, K thermocouples, max freq. 1,000Hz each
  • Digital Inputs: Coil RPM and 4 speed inputs
  • Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
  • Digital Outputs: 2, up to 1 Amp each
  • Second CAN: Yes
  • Wi-Fi Connection: Yes
  • Bluetooth: Yes
  • Internal Memory: 4GB
  • SD Card: Internal, up to 128GB
  • Connectors: 2 Motorsport connectors
  • Body: Anodised Aluminium
  • LEDs: 1 system status
  • Dimensions: 114.4 x 47.2 x 26.0mm
  • Weight: 230g
SKU: EVO6
EVO6 Tech Sheet
EVO6 Data Logger
EVO6L Data Logger
ECULog Data Logger
XLog Data Logger
  • Compact & Lightweight
  • GPS Module (Included)
  • Screenless Design
  • ECU Connection
  • CAN Output
  • 8 Analogue Inputs
  • 2 Digital Outputs
  • Wi-Fi & Bluetooth Connectivity
  • Screenless Design
  • ECU Connection
  • CAN Output
  • 5 Analogue Inputs
  • 1 Digital Output
  • Optional GPS
  • Screenless Design
  • ECU Connection
  • Built-In GPS
  • Screenless Design
  • ECU Connection
  • Weight: 230g approx.
  • Dimensions: 130.0 x 46.6 x 26.0mm
  • Dimensions: 61.4 x 44.7 x 27.2mm
  • Weight: 100g approx.
  • Weight: 150g approx.
  • EVO6
  • Chosen GPS Module
  • Harness
  • USB to 719 Adaptor
  • Mini USB-USB Cable
  • EVO6L
  • Chosen GPS Module
  • Chosen Connection Cable
  • EVO Power Cable
  • 712 to USB Cable
  • ECULog
  • Mini USB Drive 16GB
  • Harness
  • USB A to USB C Cable
  • XLog
  • Harness
  • Second CAN: Yes
  • Bluetooth: Yes
  • ECU Connections: CAN, RS232 or K-Line to +2,000 industry-leading ECUs
  • Expansions: GPS09, Lambda Sensors, SmartyCam
  • Status LED: 1
  • Connectors: 2 motorsport connectors
  • Memory: 4GB internal + removable SD memory card
  • Material: Anodised Aluminium
  • Analogue Inputs: 5 fully configurable, max freq. 1,000Hz each
  • Digital Inputs: 2 speed inputs, lap signal, coil RPM input
  • Digital Output: 1, up to 1 Amp
  • Status LED: 1
  • Connectors: 13 712 female Binder connectors
  • ECU Connections: CAN, RS232 or K-Line to 1,000+ industry leading ECUs
  • Expansions: GPS09/GPS09 Pro, ACC3, Lambda Sensors, SmartyCam
  • External Power: 9-15V
  • Connectors: 5-pin binder 712, 7-pin binder 712, USB Type-C
  • Memory: 4GB + removable USB Type-C memory key
  • Material: PA6 GS30% glass fibre reinforced
  • USB Connection: Yes
  • GPS: 25Hz
  • Wi-Fi: Built-in
  • Bluetooth: Built-in
  • Expansions: ACC3, Lambda Sensors, SmartyCam
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • Connectors: 5-pin binder 712, 8-pin binder 712, USB Type-C
  • Memory: 4GB internal + removable USB Type-C memory key
  • Battery Life: Up to 10 hours
  • Displays sold separately
