Kart Brake Pressure T-Piece
Mount Your System
The Aim Brake Pressure T-Piece is designed to mount an M10 brake pressure sensor into a brake line in an OTK kart. No adaptors are needed; the original brake line will screw onto the end of the T-Piece once fitted.
Why Choose the Aim Brake Pressure Sensor T-Piece
The Aim Brake Pressure Sensor T-Piece is ideal for OTK karts, allowing you to add a brake pressure sensor to your setup. Adding a brake pressure sensor using the T-piece provides insight into brake pressure, braking points (start and finish), driver alertness and overall brake system status, offering detailed data for performance and safety monitoring.
