Aim MyChron 2T Patch Lead Double Yellow TC Plugs
Double Temperature Sensor Cable
The Aim MyChron 2T double temperature sensor split cable allows 2 separate TC-type temperature sensors to share the same input on the MyChron 2T Lap Timer. One end features a 7-pin 712 male binder connector, and the other splits into two 2-pin TC Yellow female binder connectors. This design enables you to feed 2 different temperature sensors into your MyChron 2T from a single port, maintaining strong signal strength under race conditions.
Why Choose the Double Temperature Sensor Cable
The MyChron 2T Lap Timer (including the 4, 5, 5S and 6 models) supports 2 temperature channels but only has a single 7-pin 712 port. The double temperature sensor split cable bridges the gap by letting you connect both sensors easily. The cable is built with professional-quality leads and connectors to deliver dependable performance and long-lasting reliability.
Compatible Temperature Sensors
There are various temperature sensor combinations that can be used with this double patch lead. For example, the TC Yellow connector can fit 1 x Exhaust Gas Temperature (EGT) Sensor, either K-Type or T12, and 1 x Under Spark Plug Temperature/CHT Sensor, 2 x EGT Sensors or 2 x CHT Sensors.
Temperature Sensor Cable - Double TC
