Aim Solo 2 DL Plug & Play Cable for Suzuki Motocross ECU
Connect Your System
The Aim ECU Plug & Play Cable has been specifically designed for Suzuki motocross bikes and can be used with the Aim Solo 2 DL. The cable currently fits two Suzuki motocross bikes – RMZ 250cc 4-stroke (2010-13) and the RMZ 450cc 4-stroke (2008-13) – and is very simple to connect to allow ECU data to be logged.
Why Choose the Aim Solo 2 DL Plug & Play Cable
The Aim Solo 2 DL Plug & Play Cable is very simple to connect and integrate into your Aim setup, so you can quickly set the connection up and get your ECU data as soon as possible. Simply connect the 712 7-pin male binder to the Solo 2 DL Lap Timer and plug the other connector into your compatible ECU to begin logging ECU data. As the cable is specifically designed to be in motocross environments, it is a high-quality and long-lasting cable, so you can rely on getting your bike's data as soon as possible.
Plug & Play Compatibility
This Solo 2 DL Plug & Play Cable is compatible with the following Suzuki motocross models and years:
- Suzuki RMZ 250cc – 2010-2013
- Suzuki RMZ 450cc – 2008-2013
If you are unsure whether this ECU cable will fit your motocross bike, don't hesitate to contact our team.
Solo 2 DL スズキ RMZ ECU ケーブル
