Ducati Panigale 899, 959, 1199, 1199R, 1299, V4, V2 Aim Solo 2 DL Motorcycle Cable & Bracket
SKU: DUC-PP-DUC-1-B
- 通常価格
- £120.00
- 通常価格
- セールスプライス
- £120.00
- 単価
- あたり
Ducati Panigale 899, 959, 1199, 1199R, 1299, V4, V2 AiM Solo 2 DL Motorcycle Cable & Bracket
The AiM Ducati Panigale motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Ducati Panigale cable & bracket | 7 pin - 712 male binder connection |
Ducati Panigale Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 | Panigale V4 - From 2018 |
Panigale V2 - From 2020 |
Example data protocols
- Specifically designed Ducati Panigale Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Ducati Panigale plug & play connection cable.
- Ducati Panigale plug & play connection cable
- 1 bracket
- 1 washer
- 1 rubber dowel
The AiM Ducati Panigale motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged. The AiM Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike. Our brackets are supplied with all the necessary hardware required for fitting to your bike. Also, If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.Plug & Play
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.Expand Your System
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
- 1 bracket
- 1 washer
- 1 rubber dowel
- 選択を選択すると、ページ全体が更新されます。
