Mount Your System
The Ducati Panigale Motorcycle Bracket has been specifically designed to be a simple and secure way of mounting your Aim Solo 2 or Solo 2 DL Lap Timers. The bracket is compatible with Ducati Panigale V2, V4, 899, 959, 1199, 1199R and 1299 motorcycles.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
Supplied with all the necessary hardware, the Aim Solo 2/2 DL Motorcycle Bracket ensures that your Solo 2 GPS Lap Timer can be securely mounted to your Ducati Panigale motorcycle. This allows you to easily monitor your performance after a track day or practice to chase your desired improvements.
Ducati Panigale 1299 Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Ducati Panigale motorcycle models and years:
  • 899 Panigale – 2013-2015
  • 959 Panigale – 2016-2020
  • 1199 Panigale – 2012-2014
  • 1199R Panigale – 2015-2017
  • 1299 Panigale – 2015-2017
  • Panigale V4 – From 2018
  • Panigale V2 – From 2020
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Ducati Panigale motorcycles only
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: DUC-1-B
Part Number: X46KSTSDP
  • ドゥカティ パニガーレ ブラケット
  • x2 平頭六角ネジ M4x10mm
  • x1 丸頭六角ネジ M8x45mm
  • ゴムダボ×1
  • Washer icon
    ワッシャー×1
Ducati Panigale User Guide
Panigale V4/V2 User Guide
