Link CAN Plug
The Link Field Installable CAN Plug is ideal for custom wiring solutions and motorsport configurations to connect dash units, wideband controllers, or other CAN devices. It is intended for wiring into the 6-pin CAN port on Link G4/G4+/G4X ECUs that have a round 6-pin CAN communication port.
Please Note: The Link CAN Plug requires soldering for assembly.
Electrical
  • Maximum Input Voltage: 500V
  • Maximum Continuous Current Draw: 2A
  • Gauges of Wire: 26-24 AWG/0.14-0.25mm2
  • Dimensions: 45 x 20 x 20mm
  • Weight: 5g
SKU: CANF
PCリンクのダウンロード
