Remote Blink CAN Keypad
Free Shipping Above £100
Control Your Vehicle At Your Fingertips
The Remote Blink CAN keypad will enable you to have your very own selected buttons at your fingertips. From simply turning on the engine, the fans or the indicators, to switching gears and more, you can program the Blink CAN keypad buttons to ensure seamless performance on the road or on the track.
Integrating configurable channels, multicolour indicator rings, and the ability to be horizontally or vertically mounted, our keypads have been built to the highest standards for the harshest motorsport conditions. The keypads are available with 8 buttons or with 12.
Please Note: The keypads come blank with no inserts, of which we have an extensive range available.
Ingress Immunity
Remote Blink CAN keypads can withstand the cleaning of pressure washers and hold an IP67 rating, making them immune to the negative effects of water, mud, soil, sand, oil or chemicals.
Easy to Read
Remote Blink CAN keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
Interchangeable Inserts
Explore endless possibilities with our wide range of laser-etched inserts to personalise your keypad – whether it's for lights, heating, fans, parking, and more. You can set these buttons to react based on parameters set by you; momentary, latching and toggle modes.
