This MX UTV LCD Dash Logger is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Aim MX UTV Data Logger
The Aim MX UTV is a data logger display that has been specifically designed for off-road racing. It uses your vehicle’s ECU to acquire all the data you need to improve your racing performance.
Why Choose the MX UTV Dash Logger Kit
The Aim MX UTV dash logger has been specifically designed for the off-road world of racing. It has been engineered to offer the best technology to racers who crave the off-road experience.
The integrated GPS receiver has been tuned specifically for UTV’s and is designed to handle vibrations, direction changes, and all the lateral and longitudinal accelerations that are thrown at it.
To compute lap times, the MX UTV data logger uses GPS and Glonass data to the precision of 1/100 second. If the track you’re on is not already in the database of over 4,000 tracks, you can input coordinates or use the track recognition function that can work out the start and finish line position.
Advanced Dash Display
The MX UTV dash logger features a wide LCD screen offering a choice of 8 configurable RGB backlights. It also has an ambient light sensor that automatically switches the backlight on when encountering low light conditions, ensuring you always have maximum visibility. The 4.3" display is wide enough and bright enough to see all the data you want to see while you’re racing.
Transmission Belt Temperature
Transmission belt temperature is one of the main concerns for UTV drivers. The infrared temperature sensor in this kit makes it possible to constantly check the temperature on your dash display while you’re racing.
The configurable RGB LEDs at the top of the MX UTV dash logger will also turn on when the temperature gets to the critical level.
Configurable RGB LEDs
The top of the MX UTV dash features 5 LEDs. These can be configured to be used for 2 different functions - gear shift light or predictive lap time.
  • If you configure the LEDs for gear shift lights, this will help you choose the best time to shift gears.
  • If you configure the LEDs as the predictive lap time, they will give you a constant idea of how you are improving your lap times.
While allowing RPM monitoring at a glance, the alarms are flexible too. You can configure the situation that generates the alarm as well as the LED behaviour (blinking, frequency, and colour) when the alarm appears and the conditions for its switch off.
Integrated GPS
The MX UTV data logger features integrated GPS, which enables the MX UTV dash to automatically recognise the track you’re racing on. The dash will calculate lap times and your position on the track, and locate the start and finish line position. All your data is stored in the 4GB memory, which can log your data for several thousand hours.
  • Display Resolution: 268 x 128 pixels
  • Backlight: 8 configurable RGB colours
  • Shift Light LEDs: 5 configurable RGBs
  • Alarm LEDs: 2 configurable RGBs
  • CAN Connection: Yes
  • GPS: Integrated
  • Analogue Input: 1
  • WI-Fi Connection: Yes
  • Internal Memory: 4GB
  • Connectors: 3 binder connectors
ECU Connection
  • Model: Polaris RZR Non-Turbo - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW, Fuel Rate
  • Model: Polaris RZR Turbo - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW, Fuel Rate, Boost Pressure, Charge Air Temp (from request)
  • Model: CAN-AM Non-Turbo - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW, Instant Fuel Flow
  • Model: CAN-AM Turbo - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW, Instant Fuel Consumed, Boost Pressure, Intake Air Temp
  • Model: Yamaha YXZ 2016 - Channels: Speed, RPM, Gear, ECT
  • Model: Yamaha YXZ 2017 - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW
  • Model: Arctic Cat Wildcat - Channels: Speed, RPM, Gear, ECT, TPS, BrakeSW
  • Weight: 330g
SKU: MXUTV-X85MXUTV001
  • AiM MX UTV LCD Dash Logger with Temperature Sensor - AimShop.com
    MX UTV Dash Logger
  • AiM Solo 2 DL CAN / RS232 2M External Power Cable Motocross - AimShop.com
    CAN & Power Cable
  • AiM Infrared Belt Temperature System (IBTS) Single Point Sensor - AimShop.com
    Single Point Belt Temp Sensor with Fixing Kit
  • Cable icon
    Sensor Extension Cable
MX UTV Tech Sheet
MX UTV User Guide
