Aim XLog & Suspension Potentiometer Mountain Bike Kit
The Ultimate Mountain Bike Setup
Combine the XLog, a small, waterproof, 25Hz GPS data logger; the ACC3, our unbeaten Analogue CAN Converter; Suspension Potentiometers, and you can even connect the ultimate camera - the SmartyCam 3 Sport, to become the best rider and beat your best lap times.
Why Choose the XLog Mountain Bike Kit
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. Combined with the ACC3 and Suspension Potentiometers, you will find the ultimate key to control, analysis and improvement.
XLog Features
The XLog calculates and records:
- Lap times
- Sector times
- Vehicle position and speed
- 3D acceleration and gyro
In addition, the XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can add brake pressure sensors, analogue inputs, and a professional motorsport camera for enhanced functionalities.
The Aim ACC3 is an Analogue CAN Converter, built practically for a range of motorsport disciplines, including downhill mountain bike applications. Its compact design ensures easy installation across a range of racing disciplines, while its robust construction guarantees reliability in demanding environments. When combined with Race Studio 3 software, the ACC3 unlocks powerful configuration and analysis tools, including suspension analysis with Aim Eclipse sensors and video synchronisation with SmartyCam 3 cameras.
The ACC3 supports up to 4 analogue inputs with frequencies up to 200Hz.
XLog GPS & Inertial Platform
- GPS Technology: Tracks position and speed at 25Hz using four satellite constellations (GPS, GLONASS, BeiDou, Galileo) with <0.5m precision.
- 6-Axis IMU: Records 3D accelerations and angular velocity at 100Hz, allowing in-depth analysis of braking, acceleration, and chassis behaviour.
- Lap Timing & Sectors: Samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
Compact, Durable Design
Measuring only 72.3 × 65.3 × 30.3mm, the XLog is compact to fit in even the tightest setup. Its rugged, waterproof housing ensures reliable operation in all conditions. With a built-in rechargeable lithium battery (up to 10 hours) and support for an external 8–16V supply, the XLog is built for trackside convenience.
Analyse with Race Studio 3
Analyse lap times, sector times, GPS maps, accelerations, and video (when paired with a SmartyCam 3) to improve your performance and understand your bike in detail.
The XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can integrate brake pressure sensors and a professional motorsport camera for enhanced functionalities.
Integrate the ACC3 that comes in the kit to sample data coming from suspension and pressure; you will also be able to integrate a SmartyCam 3, sold separately, taking your data to the next level by incorporating synchronised video footage to overlay the data recorded by the XLog data logger onto your footage post-session with Race Studio 3.
XLog
ACC3
ACC3 4-Channel Harness
x2 サスペンションポテンショメータ
- Data/Dash Loggers: Solo 2 DL, MyChron Series, EVO4S/EVO5, and MX Series dashes.
- Sensors: K-type thermocouples, thermo resistors, 0-5V sensors and 0-12V sensors.
- Expansion Modules: SmartyCam cameras, LCU-One Lambda controllers and CAN expansion modules.
