CAN Connection Harness for MX Stradas
The Aim 14-Pin CAN Harness lets you connect your MX Strada Dash Display to vehicle wiring via the CAN network: quick, reliable and designed for plug & play installation. This harness features a 14-pin AMP female connector, a 4-pin 719 female Binder and a 5-pin 712 female Binder, all pre-wired for CAN communication.
Why Choose the Aim 14-Pin CAN Harness
The Aim 14-Pin CAN Connection Harness is designed for use with devices from the MX Strada Series, giving you perfect compatibility with minimal wiring confusion. It keeps signal integrity strong and makes integration into track or road vehicles straightforward.
The CAN Harness is ideal for installation in cars, track vehicles and performance road builds utilising CAN-bus systems and perfect if you’re transferring your dash to another vehicle or replacing a damaged loom.
  • 14-pin AMP female flying connector
  • 4-pin 719 female Binder
  • 5-pin 712 female Binder
  • x5 1x0.5 cables
SKU: MX-S-L-CAN-V02573320
Part Number: V02573320
MX Strada ハーネス テックシート
