Aim 719-719 Male to Female 4-Pin Patch Lead
Connect Your System
The Aim 719-719 patch lead is a durable extension cable with 4-pin male and female connectors designed for connecting sensors or expanding the original wiring harness. Featuring quick and easy to use secure push-on connectors, it always ensures reliable signal transmission.
Why Choose the Aim 719-719 Patch Lead
The Aim 719-719 patch lead simplifies installation and setup, allowing easy connection between sensors, expansion hubs, or modules without complex rewiring. It's ideal for clean, organised sensor layouts. The 4-pin male to female lead is available in multiple lengths (0.5m, 1m, 1.5m, 2m, 2.5m, 3m, 3.5m, and 4m) and is compatible with Aim systems such as the Aim MXG, MXS, MXP, and other devices using 719 connectors.
Essentially, the 719-719 patch lead is used to extend your connections or integrate additional modules, ensuring flexibility and reliability across your Aim racing setup.
719-719 オス - メス パッチ リード
