コンテンツへスキップ
ログイン
検索
検索 ログイン カート 0
カート
  • お買い物を続ける
あと £50.00で送料無料です!
    特別注文
    税および送料はチェックアウト時に計算されます。
    小計(税込)
    カートを見る
    検索
    AiM Car Steering Angle Rotary Potentiometer/ Belt Type Sensor - AimShop.com
    Aim Steering Angle (Rotary Potentiometer/Belt Type) 1 Rev Kart Sensor - AimShop.com
    Aim Car Steering Angle Rotary Potentiometer/ Belt Type Sensor - AimShop.com
    S-SA-X05SNST10G-S-SA-P-712-719-5
    Aim Car Steering Angle Rotary Potentiometer/Belt Type Sensor
    £170.00
    このアイテムは定期購入または後払い購入です。続行することにより、キャンセルポリシーに同意し、注文がフルフィルメントされるまで、もしくは許可される場合はキャンセルするまで、このページに記載されている価格、頻度、日付で選択した決済方法に請求することを承認するものとします。
    • Facebookにシェア
    • 共有する
    • 共有する
    • Facebook Facebookにシェア
    • WhatsApp 共有する
    • E-mail 共有する
    £170.00
    The AiM Steering angle (rotary potentiometer) sensor comes with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
    Measures the angle of a steering wheel Supplied with mounting a bracket
    719 4 pin male connector 10 Revolutions
    The steering angle sensor measures the angle of the steering wheel in degrees and is used to highlight over/under steering situations. It can pick out and see if the driver is losing time due to the steering input.
    The sensor measures the angle of the steering wheel in degrees as the driver turns the wheel.
    As the wheel is turned, you can see how much steering input has been put in. You can then pick out and see if the driver is losing time due to steering. This could be due to turning too much or too little into a corner.
    MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres.
    For most installations, you will need one of these leads.
    • Nominal Resistance: 10K ohm
    • Tolerance on Resistance Value: 5%
    • Precision: 0.030%
    • Mechanical Displacement: 3600°
    • Working Temperature Range: -55/+125°C
    • Cable Length: 30cm
    • 10G Steering Potentiometer
    • 1 Toothed Belt
    • 2 Toothed Pulleys
    • 1 Allen Key
    • 1 Bracket Kit
    User Guide
    Use our 24/7 AI chat support, or call us from Monday to Friday between 09:00 and 17:00 BST
    Next-day delivery options available, and same-day shipping guarantee when you order before 15:00 BST Monday - Friday
    • よくある質問
    • ソフトウェア
    • ウェビナートレーニング
    • 製品ガイドPDF
    • ニュースレター
    • お問い合わせ
    • アフィリエイトになる
    • 修理
    • ライブチャットとサポート
    • 選択をするとページが更新されます。
    • 新しいウィンドウで開きます。
