Aim MyChron 6 から ACC3 への分割ハーネス
Connect Your System
The MyChron to ACC3 Split Harness is an optional cable that expands your MyChron system by connecting it to an ACC3 (Analogue CAN Converter).
Why Choose the MyChron to ACC3 Split Harness
The Aim MyChron to ACC3 Split Harness is ideal for connecting the MyChron 6
and 6 2T to the ACC3; by connecting these modules you will have four additional
channels and a CAN bus for integration with a wide range of Aim products.
How the MyChron to ACC3 Split Harness Works
The Aim Analogue CAN Converter is a compact and powerful module designed
to extend the data acquisition capabilities of your logger. Managing up to 4
channels at 200Hz each, the ACC3 allows you to capture and analyse additional
sensor data with precision.
To use in ACC3 in conjunction with the MyChron 6 / 6 2T, you will require the
MyChron to ACC3 Split Harness. Using these products together unlocks data
inputs that expand your set-up, allowing you to analyse multiple different areas
of your racing. Track your temperatures, lambda, tyres, pressures, and record it
all on a robust motorsport camera, perfectly designed for kart racing to capture
every single bit of your time on track. You can also overlay all synchronised data
from your additional expansions onto your video footage, giving you the full
range of analysis in one place.
Expansion Capabilities
The ACC3 adds four channels and a CAN bus for integration with the LCU-One S Lambda Controller, SmartyCam 3, or Tyre Temperature Kit, and runs on external power. LCU-One S provides adaptable fuel monitoring, and SmartyCam 3 Sport records synchronised video and telemetry for analysis in Race Studio 3.
MyChron を ACC3 スプリット ハーネスに選択
