AiM MyChron Magnetic Lap Receiver
SKU: S-MG
- 通常価格
- £125.00
- 通常価格
- セールスプライス
- £125.00
- 単価
- あたり
+ VAT(英国のみ)
This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.
Magnetic lap receiver | 712 - 4 pin binder connector |
Suitable for MyChron4, MyChron5 | |
The sensor triggers the timer when it passes over the magnetic timing strip fitted to most kart tracks.
Replacement sensor for MyChron4
Compatible with MyChron5
Triggers lap times from the magnetic strip found in kart tracks
- 712 - 4 pins Binder Connector
- 1 x AiM Magnetic Lap Receiver
This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.Key Features :
This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.The sensor triggers the timer when it passes over the magnetic timing strip fitted to most kart tracks.
- 選択を選択すると、ページ全体が更新されます。
