Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Female Jack Plug for External Microphone
Power Your System
The Aim SmartyCam ECU Harness is an external power cable to allow a 12V battery connection, with a female jack plug for an external microphone to be connected. It has motorsport-engineered grade cables and fittings to withstand many different environments.
Why Choose the SmartyCam External Power Cable
The power cable is a useful accessory for when you want the reassurance of having the camera powered from your vehicles 12V system. The female 3.5mm jack allows you to connect an on-board radio to an intercom system (additional cable may be required depending on your radio/intercom). Essentially, the Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Female Jack Plug for External Microphone provides direct battery power supply to an Aim SmartyCam camera, and features CAN high and CAN low connection inputs for the ECU.
Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash, as the power will be supplied to the camera through the CAN connection.
電源、ECU CAN & ジャックプラグケーブル
