Mount Your System
The Aim SmartyCam GP Suction Cup Mount is specifically built for simply mounting the Aim SmartyCam GP Recording Box to a windscreen or any flat surface of your vehicle. It is compatible with a range of SmartyCam GP models, from the 2.1 and 2.2 to the most recent 3, including the GP Pro.
Why Choose the SmartyCam GP Suction Cup Mount
The SmartyCam GP Recording Box Suction Cup Mount is designed to secure a GP camera setup in a clear position where it isn’t in the way. The mount is easy to set up; simply latch the suction cup onto any flat surface, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust where the recording box sits for optimum positioning and has been designed to withstand the rigours of motorsport.
  • For use with SmartyCam GP 2.1 & 2.2 & 3 recording box
  • Ball & socket adjustment system
  • Includes fixtures and fittings for a secure fit
  • Designed to withstand the rigours of motorsport
  • Suction cup
  • 90mm arm
  • Clamp base with ball
  • Mounting bracket
  • Locknuts
  • Washers & screws
SKU: SM-WM-GP-R
