Aim SmartyCam Mini Roll Cage Mount
Mount Your System
The Aim SmartyCam Mini Roll Cage Mount has been specifically designed to hold and position SmartyCam cameras onto a roll bar tube. It is compatible with SmartyCam 2.1, 2.2, 3 & 4 Sport, Corsa or the older HD model.
Why Choose the SmartyCam Mini Roll Cage Mount
The Aim SmartyCam Mini Roll Cage Mount is made up of aluminium, with a black anodised finish and is specifically designed to withstand the rigours of motorsport use. The 2 jubilee clips allow for easy fitting of the camera to different roll cage tube diameters, and the clamp is available with standard or extended lengths.
Chosen Roll Cage Mount
44mm & 55mm ジュビリー クリップ
