Aim SmartyCam U Bolt Mount
Mount Your System
The Aim SmartyCam U Bolt Mount is a simple, but secure way of integrating your SmartyCam into a vehicle’s roll bar, railing or tube that has a diameter between 0.5 and 1.2 inches. It is compatible with the SmartyCam 2.1, 2.2, 3 and 4 Sport, Corsa & HD models.
Why Choose the Aim SmartyCam U Bolt Mount
The Aim SmartyCam U Bolt Mount is a versatile way to secure a SmartyCam to a range of vehicle setups. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust your camera angle, while the rubber insert minimises vibration, ensuring you get the best recordings of your laps.
