AiM Weld on Tab for Dash Bracket
SKU: UP-TAB
- 通常価格
- £3.00
- 通常価格
- セールスプライス
- £3.00
- 単価
- あたり
+ VAT(英国のみ)
Weld on Tab
A simple weld on the chassis tab to facilitate dash and button mounts.
Key Features:
Weld on Tab
A simple weld on the chassis tab to facilitate our modular dash/button mounts. 3mm Mild Steel Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash / lap timer/shift lights. |
Aim Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today. |
Unlock your potential |
- 3mm mild steel
Weld on Tab
Key Features:
Weld on Tab
- 3mm mild steel
Whats In The Box
- 選択を選択すると、ページ全体が更新されます。
