製品情報にスキップ
1 2
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: APR-PP
通常価格
£60.00
通常価格
セールスプライス
£60.00
注文すべてでカーボンニュートラルな配送
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Aprilia bikes. Allowing easy installation to a Solo 2 DL or EVO4S Data Logger. With a 7-pin 712 male binder connection.
Aprilia plug & play cable 7 pin - 712 male binder connection
The plug & play cable currently fits the following Aprilia bike models:
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
Example data protocols
  • Below is a pinout drawing for the Aprilia plug & play connection cable
  • Aprilia RSV4 Plug & Play connection cable
The cable is an easy fitment to your bike and allows ECU data to be logged. Please Note: If you are unsure this ECU cable will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
