Link Air Temp Sensor (IAT1-8)
SKU: IAT1-8
- 通常価格
- £53.55
- 通常価格
£63.00 - セールスプライス
- £53.55
- 単価
- あたり
The Link Air Temperature Sensor measures the temperature of the incoming air to the engine. This information is provided to the ECU to determine the correct amount of fuel needed for optimum performance and economy.
Includes 2-pin Deutsch DTM connector kit
Aluminium and steel weld in mounting bosses available
1/8" BSP Thread
- Link Air Temp Sensor
- 2-pin Deutsch DTM connector kit
The Link Air Temperature Sensor measures the temperature of the incoming air to the engine. This information is provided to the ECU to determine the correct amount of fuel needed for optimum performance and economy.Includes 2-pin Deutsch DTM connector kit
1/8" BSP Thread
Technical Specifications
- 選択を選択すると、ページ全体が更新されます。
