Link Knock Sensor (KNS)
SKU: KNS
- 通常価格
- £80.00
- 通常価格
- セールスプライス
- £80.00
- 単価
- あたり
“Knocking” occurs when the air-fuel mixture self-ignites prematurely. Sustained knocking causes damage primarily to the cylinder head gasket and cylinder head. The knock sensor identifies the high-frequency engine vibrations characteristic of knocking and transmits a signal to the ECU. The aim is to obtain the maximum energy yield by starting ignition as early as possible. Engines with a knock sensor can reduce fuel consumption and increase torque.
Donut style
8mm hole
Includes plug and pin kit
- Knock Sensor
- Plug and Pin Kit
“Knocking” occurs when the air-fuel mixture self-ignites prematurely. Sustained knocking causes damage primarily to the cylinder head gasket and cylinder head. The knock sensor identifies the high-frequency engine vibrations characteristic of knocking and transmits a signal to the ECU. The aim is to obtain the maximum energy yield by starting ignition as early as possible. Engines with a knock sensor can reduce fuel consumption and increase torque.Donut style
8mm hole
- Knock Sensor
- Plug and Pin Kit
- 選択を選択すると、ページ全体が更新されます。
