The Aim MyChron 6 2T is our best-selling GPS lap timer with two sensor connections, specifically crafted for karting. Combining 30 years of experience with advanced technology, the MyChron 6 2T offers precise lap timing and advanced data analysis for both amateur and professional racers.
Why Choose the MyChron 6 2T GPS Lap Timer 
The MyChron 6 2T GPS lap timer revolutionises how drivers and teams monitor and analyse performance on track.
Due to its highly accurate 25Hz GPS tracking, large screen displaying delta times and comprehensive data logging capabilities, the MyChron 6 2T provides detailed performance analysis from split times and overall delta time, racing lines, cornering speeds and braking points.
Note: The MyChron 6 2T is compatible with the most common heart rate monitors on the market.
Advanced Display
The MyChron 6 2T features a wide graphical display, ensuring excellent readability. Brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions, and this allows drivers to clearly monitor not only their best vs current sector times, but also their heart rate, delta, delta bar graphs and more, allowing real time adjustments to be made, improving lap performance.
LED & Alarms System
Available Sensors
With the MyChron 6 2T, you can select two temperature sensors to monitor your engine more precisely. Choose from:
  • Cylinder Head Temperature (CHT) Sensor: This under plug sensor measures combustion heat, helping detect overheating from lean mixtures or aggressive tuning.
  • Exhaust Gas Temperature (EGT) Sensors: M5 and T12 sensors monitor exhaust temps to fine-tune fuel mixture and optimise performance.
  • Water Temperature Sensors: Available in M10 (for Rotax, X30, OK) and M5 gearbox versions, these sensors track coolant temps to prevent overheating, with the M5 also being useful for monitoring gearbox water cooling in shifter karts.
Choosing the right pair depends on your engine type and what areas you want to monitor most closely.
Using 2 temperature sensors together gives a deeper view of engine performance and reliability. A popular combo is an EGT and CHT, ideal for air-cooled engines, providing insight into fuel mixture and combustion heat. EGT and water temp sensors suit water-cooled engines like Rotax or X30, balancing tuning with cooling system monitoring.
For shifter karts, pairing gearbox water temp (M5) with either EGT or CHT helps monitor both engine and gearbox temps, preventing wear. Some setups also run dual water temp sensors (M10 + M5) to track both engine and gearbox cooling separately.
The right pairing depends on your engine type and what you need to monitor; performance, cooling, or both.
  • Display: Graphical
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • Bluetooth Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • CAN Connections: 2
  • Connectors: 1 connector (binder) 712 fem 7 pins, 1 connector (binder) 712 fem 8 pins & 1 connector (binder) 712 fem 5 pins
  • USB Connection: For data download, mass storage support and battery charge
  • Temperature Inputs: 2
  • Digital Inputs: Optical lap signal, magnetic lap signal
  • External Modules: MyChron Expansions, IR Temperature Controller, SmartyCam 3 Series, Lambda (LCU-One and LCU1S)
  • Memory: 4GB
  • Battery Life: 20h approx.
  • Body: PA6 GS30%
  • Dimensions: 150.0 x 79.0 x 36.6mm
  • Weight: 370g
  • IP67
SKU: MY62T
MyChron 6 User Guide
MyChron 6 Tech Sheet
