Second-Life Out of Production EVO4 Data Logger
The EVO4 Data Logger
The EVO4 is a powerful and flexible data logger that offers a range of sources for your data. It is a great tool for track days to help improve your performance.
Why Choose the Aim EVO4 Data Logger
The Aim EVO4 power cable offers a direct, dependable power connection tailored for the EVO4 system, replacing worn or damaged cables without needing to rewire the entire harness. The power cable is rated for inputs from 9-15V and includes a battery ground lead, making it suitable for typical road or race electrical systems.
Essentially, the Aim EVO4 power cable is ideal when you need a reliable, OEM-style replacement or spare power cable to ensure consistent logger operation.
Powerful and Flexible Data Logging
The Aim EVO4 is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4 samples all the information you need, data coming from your vehicle's ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro and the GPS Module included in the kit.
Select which harness you require CAN, RS232 or OBD11, and select which GPS Module best meets your requirements. You can also upgrade your kit with our GS-Dash display and Formula Steering Wheel, allowing you to really improve your performance on track days.
Optional Expansions
SmartyCam Cameras: Onboard cameras that overlay onto all your videos all the data sampled by your logger.
EVO4
