This SmartyCamHD 2.1 is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Robust Motorsport Camera
Designed for motorsport environments with a single purpose to provide you with great videos that include all the technical information that will help you improve your performance. All this in the most robust and reliable system ever.
Why Choose the Aim SmartyCam HD 2.1
Compact in size, the Aim SmartyCam HD 2.1 is ideal for installation in most motorsport setups. Its aluminium casing makes it extremely lightweight, robust and reliable too, so you can get all the footage you need directly from the driver's seat.
The narrow 67° HFOV lens is preferred for closed-roof cars, as it “sees” the track just within the windscreen pillars, reducing that unpleasant black frame that is typical of generic camera on-board videos.
Second-Life Smartycam HD(Rev.2.1)
Real Time Data Overlay
The SmartyCam HD 2.1 camera automatically overlays on your video all the data you need: speed, RPM, lap number, gear shifts, and much more. Simply choose the data and graphical layout you prefer from the different overlays available.
Data can be read from a number of sources. From GPS track map and vehicle position, as well as speed, lap times and split times. Aim logger/dash logger connected to your ECU - RPM, throttle, engaged gear, acceleration, temperatures, pressures, etc.
Automatic Start & Stop
The SmartyCam HD 2.1 can be switched on by the logger it is connected to. Switch off is automatic; simply decide after what period of non-activity the camera will switch off. Both operations can also be carried out using the keyboard if you prefer.
Recording can also be started/stopped automatically or via keyboard. The camera will start recording when the speed or RPM threshold is exceeded. In this case, you simply decide how long after dropping below the selected threshold the video will automatically stop.
Global Shutter CMOS Sensor
Unlike generic multipurpose cameras, the SmartyCam HD 2.1 has been designed to avoid the problem of image distortion, thanks to the innovative Global Shutter CMOS sensor. The camera shutter captures the entire image at the same time, not “pixel by pixel” like traditional sensors. The result is that images are captured at once and are not affected by the vibrations that happen on a racing vehicle, which creates the so-called “wave effect”.
No “Wave Effect” & Improved Quality
Engine rumble causes vibrations which are not a good thing for video recording. Never again will you experience that seasick “wave effect” you get when watching videos recorded by a generic camera, when the car rolls at 7000 RPM. SmartyCam HD 2.1 has been designed for that environment and for those vibrations. “Wave effect” is just a memory.
Proprietary Lenses Designed For Motorsport
A lens specifically designed for motorsport must be robust, be able to work when the engine rolls 100 times per second, and have good resolution and brightness. But above all, a lens designed for motorsport must reduce distortion, which is a typical problem of lenses used by generic action-cameras. SmartyCam HD telecentric lens with six elements reduces distortion to a minimum and will withstand track vibrations for years. The 67° provides a narrow-angle, horizontal field of view (HFOV), making it ideal for capturing the view between the windscreen pillars.
Front Mount Colour TFT Display
On-board cameras are to be installed inside the car. Where should the display be placed to check the correct position of the camera? The SmartyCam HD 128x128 pixel TFT colour display is on the front, not on rear – where general cameras place the viewfinder.
High Motorsport Quality – Small Size Video Files
Most other HD cameras are focused on the highest pixel number. The result is that their video files are far too large, taking up too much memory. SmartyCam HD videos have the same quality as other HD cameras, but their files are smaller because the H264 compression system parameters have been optimised to a perfect balance between video quality and file size.
You can choose among three video file quality levels: one-hour recording takes 4GB (high quality), 2GB (normal) or 1.5GB (low).
Designed to Withstand Extreme On-Track Conditions
The SmartyCam HD 2.1 onboard camera is specifically designed for motorsport, guaranteeing great resistance against the extreme working conditions typical of track racing and against the most adverse weather.
Video Analysis
The video of a whole session once downloaded on your PC can now be split with a simple click in individual videos of each lap: so that you can simultaneously watch two of them and check where you were faster or slower. The same operation can be performed with any SmartyCam HD video recorded on the same track you will be able to compare your best lap with your friends personal best.
Camera Connections
The perfect connection to get all your data from the ECU merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
SmartyCam can be used with all of our Aim dash display loggers (except Solo 2). With our data hub 4x CAN connection multiplier you can add a GPS Module or extra cameras  to your system.
  • Video Format: H.264 1280 X 720 pixels @ 30fps
  • Display Resolution: 128 X 128 pixels
  • Lens: Telecentric with 6 elements
  • Field of View: 67°
  • Internal Battery: Rechargeable Lithium Battery - 1,950mAh
  • Battery Charge: 700 mAh 12V
  • Internal Battery Duration: 120 - 150 of recording
  • External Power: 9 - 15V
  • Supported SD Card: Up to 128 GB
  • Memory Capability: 1.5GB (1 hour low quality recording), 2GB (1 hour medium quality recording), 4GB (1 hour high quality recording)
  • Accelerometer: Three-axial + 5G
  • Usage Temperatures: -10°C / +60°C
  • Auto Power ON: Yes if connected to the Aim logger
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Dimensions: 87 x 63 x 49mm
  • Weight: 280g battery included
  • Waterproof: IP67
SN: 3811837
SmartyCam HD 2.1 User Guide
SmartyCam HD 2.1 Tech Sheet
