22-Pin CAN/RS232 & Expansion Harness for SmartyCam Dual
Power Your System
The 22-Pin CAN / RS232 & Expansion Harness with optional ethernet & optional 3.5mm microphone jack is a purpose-built connectivity solution designed for seamless integration with the SmartyCam 3 Dual system.
Why Choose the SmartyCam External Power Cable
Engineered for use with the SmartyCam 3 Dual, this harness enables reliable communication between your camera and vehicle systems through CAN and RS232 interfaces, ensuring accurate telemetry capture and synchronisation with onboard data sources. The integrated ethernet connection provides high-speed data transfer and system expansion capability, while the 3.5mm jack input allows direct connection of an external microphone for clear, high-quality audio recording in demanding environments.
Whether used for driver coaching, performance analysis, or professional motorsport broadcasting, this expansion harness unlocks the full potential of the SmartyCam 3 Dual system by combining video, telemetry, and audio into a single, integrated workflow.
Your Chosen Harness
