Double Speed Sensor Split Cable
The Aim EVO4S double speed sensor split cable allows 2 separate 719-type speed sensors to share the same input on the EVO4S data logger. One end features a 4-pin 719 female Binder connector, and the other splits into 2 4-pin 719 male Binder connectors. This design enables you to feed 2 different speed sensors into your EVO4S logger from a single port, maintaining strong signal strength under race conditions.
Why Choose the Double Speed Sensor Cable
The EVO4S supports 2 speed channels but only has a single physical speed port. The double speed sensor split cable bridges the gap by letting you connect both sensors easily. The cable is built with professional-quality leads and connectors to deliver dependable performance and long-lasting reliability.
  • For Aim EVO4S data logger
  • Allows 2 speed inputs
  • 4-pin female 719 Binder
  • Split 4-pin male 719 Binders
SKU: EVO4-SSC-719-719
Speed ​​Sensor Tech Sheet
