Aim GT32 Rattutvidelsesledning
GT32 Steering Wheel Expansion Harness
The Aim GT32 steering wheel expansion harness is a pre-made wiring harness with the correct Aim connector already attached. It plugs directly into the GT32 steering wheel, while the other end plugs into your Aim PDM08/PDM32.
With no loose wires and no custom wiring, it is a simple and clean install.
Why Choose the GT32 Expansion Harness
The Aim GT32 steering wheel expansion harness allows all your steering wheel functions to communicate with your Aim network:
- Buttons (radio, pit limiter, flash, drink, etc)
- Rotary switches (traction control, engine map, brake bias adjust)
- Paddle shifters
- Clutch paddles
- Display and CAN communication
GT32 EXP sele
