Aim MXG Dash Bracket
Choose Accessories
Mount Your System
The Aim MXG Dash Bracket is a 2mm thick raw stainless steel mounting plate that has been designed to fit the MXG Dash directly to the steering wheel column. The mounting bracket accommodates 160mm × 60mm bolt hole spacing for the dash and can be used with a single-mount centre hub or secured with weld-on or bolt-on tabs to your chassis or column as required.
Why Choose the Aim MXG Dash Bracket
Due to the dash displays larger size, the MXG Dash Bracket is especially well suited to being mounted on a central hub or strong structural point, rather than on a thin steering wheel plate. Using this Aim MXG Dash Bracket provides a secure, clean mounting solution for your MXG Dash Display, making it an ideal choice for many motorsport setups.
MXG Dash-brakett
