Gå til produktinformasjon
1 av 2
AiM Oil/Water Thermocouple Temperature Sensor M10 K Type Motocross
SKU: S-T-M5-M-MX
£70.00
£70.00
The AiM water thermocouple temperature sensor with M10 thread allows you to measure water temperature by placing the thermocouple in the cooling system.
Measure water temperature  Thermocouple male fitting
Wide temperature range
It can measure the water temperature by being placed in the cooling system. When fitting the sensor, ensure it is far from heat and electromagnetic interference sources like the RPM cable or lap receiver cables.
Temperature range of 0-150°C
Sensor cable length 25cm
  • Temperature working range: 0-150°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Thermocouple M10 Water Temperature Sensor
To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug) or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger, you will need a TC yellow 712 3 pin patch lead (metal binder plug). MXS, MXG, MXP, MXL2 and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash/loggers, you need to use the dedicated harness supplied with your device.
