Aim PDM08 Forhåndstildelt 3m svart tilkoblingsledning
PDM08 Connection Harness
The Aim PDM08 black connection harness is designed specifically for the Aim PDM08 power distribution module. Each wire is colour-coded and clearly tagged, simplifying installation and eliminating guesswork during setup. With a straight 3 metre length and pre-assigned wires, it ensures an easy, clean, professional installation in your vehicle.
Why Choose the Aim PDM08 Black Connection Harness
The Aim black connection harness is built using high-quality professional cables, matching the standard and reliability expected from Aim systems and supports full PDM08 functionality without the need for custom wiring. Ideal if you’re replacing a damaged harness or installing a new setup, this PDM08 harness gives you perfect compatibility, dependable signal connections, and time saved in wiring.
Black PDM08 Connection Harness
