Aim SmartyCam Bullet-kameraglassutskiftningssett
SmartyCam Spares
The Aim SmartyCam Glass Replacement provides a direct replacement for the Aim SmartyCam 2.1, 2.2, 3 & 4 GP & Dual bullet cameras. It provides a glass outer lens and o-ring for a secure fit.
Why Choose the Bullet Camera Glass Replacement Kit
This lens protector is designed to fit the Aim SmartyCam GP & Dual bullet cameras (versions 2.1, 2.2, 3 & 4) and is the same as supplied with the camera. They are manufactured from Methacrylate to provide anti-glare and scratch protection. The Bullet Camera Glass Replacement Kit is ideal for replacing damaged protectors or keeping as a spare.
Bullet Camera Glass Kit
