SmartyCam GP Roll Cage Mount for Recording Box
Mount Your System
The Aim SmartyCam GP Roll Cage Mount has been specifically designed for securely mounting the SmartyCam’s recording box to a railing, tubing or roll bar. It is suitable for the SmartyCam 2.1, 2.2 and 3 GP, including the GP Pro.
Why Choose the SmartyCam Recording Box Roll Cage Mount
The Aim SmartyCam GP Roll Cage Mount is the most secure and easiest way to mount your SmartyCam’s recording box when you’re on the track in your vehicle. The mount is simple to attach, suiting a variety of roll cage diameters for the perfect setup. The ball and socket allows you to conveniently position the recording box with ease, while the included rubber inserts and locknuts provide a secure installation.
