    Aim Solo Roll Bar Mount (V Bracket) - AimShop.com
    SOLO-VB
    In stock, ready to ship
    £68.00
    Product Image
    £68.00
    Aim Solo, Solo 2, Solo 2 DL Roll Bar Mount (V Bracket)
    The Aim Roll Bar mount is suitable to be clamped to a roll bar, railing or tube. Used to secure for Solo GPS lap timer to your vehicle.
    Secure mounting for GPS lap timer Ball & socket for positioning
    Suitable for Solo, Solo 2 & Solo 2 DL
    Roll Bar Mount for GPS Lap Timer
    The Aim Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
    It is used to securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap Timers to your vehicle. The V bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to a roll bar, railing or tube.
    The duel swivel joint makes the viewing angle adjustment quick and easy and the securing clip has a rubber lining to prevent slipping and any vibrations affecting the display.
    These are some of the items that can be added to your setup for incrementing performance and data.
    • 90mm arm
    • Rollbar bracket
    • Clamp base with ball
    • Locknut
    • 4.5cm and 5.5cm tube clamp
    • Gasket
    • Screws and washers
    • 1 Roll Bar Mount Bracket for Solo, Solo 2, Solo 2 DL
