    Aim Weld-On Tab for Dash Bracket - AimShop.com
    UP-TAB
    In stock
    £3.50
    £3.50
    Weld on Tab
    A simple weld on the chassis tab to facilitate dash and button mounts.
    Key Features:
    • Weld on a tab mount
    • 3mm stainless steel
    • Free race studio 3 download
    Weld on Tab
    A simple weld on the chassis tab to facilitate our modular dash/button mounts.
    3mm Mild Steel
    Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays/buttons/dash / lap timer/shift lights.
    Aim Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.
    Unlock your potential
      AiM Weld on Tab for Dash Bracket
      • 3mm mild steel
      Whats In The Box
      Technical Sheet
