Search Login Cart 1
You are eligible for free shipping.
  • AiM Car 5-inch TFT dash display with road icons for PDM08 and PDM32
    Aim 5" TFT Dash Display with Road Icons for PDM08/PDM32
    £295.00
    Remove
£295.00
AiM Accessories Deutsch DTM male and female plugs with pins and wedge lock connectors
P-DTM
Deutsch Male & Female DTM Plug & Pins including Wedge Lock
£8.00
£8.00
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.
Male & Female DTM plugs Pins & wedge lock
2 to 12 way options
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
  • Tactile and audible connector mating
  • Rugged thermoplastic connector housing
  • Hand insertable/removable connects
  • Operating temperature range: -55 to +125°C
  • Positive contact retention
  • 1 x DTM Deutsch plug, pins, wedge lock
  • Vanlige spørsmål
  • Programvare
  • Støttevideoer
  • Produktveiledning PDF
  • Kontakt oss
  • Bli en ambassadør
  • Reparasjoner
  • Live Chat & Støtte
