Gå til produktinformasjon
1 av 2
Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
£67.00
£67.00
Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Hypermotard plug & play cable 7 pin - 712 male binder connection
Ducati Hypermotard Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Hypermotard bike model:
Hypermotard 796 - 2009-2011
Example data protocols
  • Below is a pinout drawing for the Ducati Hypermotard plug & play connection cable
  • Ducati Hypermotard Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger. The cable is an easy fitment to your bike and allows ECU data to be logged.  Please Note: If you are unsure this ECU cable will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
