    Second-Life Aim SmartyCam 3 120º Bullet Camera Replacement - AimShop.com
    Compact & Lightweight
    Robust & Reliable
    Replacement or Spare
    For SmartyCam Dual & GP
    SN: N/A
    Hurry, only 3 items left in stock!
    £200.00
    Robust & Reliable
    £200.00
    These 120º Bullet Camera Replacements are fully equipped and ready to take on their second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
    The Aim SmartyCam 3 replacement Bullet Camera is a lightweight, robust replacement or spare part for your camera kit.
    High-Quality Camera Replacement for SmartyCam 3
    Compact & Robust 120º Lens
    Replacement Bullet Camera
    The Aim replacement bullet camera has been designed for motorsport and is incredibly light and robust.
    The bullet camera is black anodised, billet machined, small and compact enough to fit into the tightest of locations.
    Ideal to have one spare at the track in case your camera gets damaged.
    If you have multiple vehicles, you can have the correct lens for each specific vehicle.
    Provides high-quality footage.
    Please Note: This replacement Bullet Camera is for the SmartyCam 3 and is 120º.
    We also have bullet replacement front glass kits available in three different lens applications.
    These are some of the items that can be added to your vehicle for incrementing performance and data.
    Aim SmartyCam 3 Bullet Camera Replacement
    • Anodised black
    • Billet machined
    • 1 x 120º Replacement Bullet Camera
