Yamaha Motorcycle ECU Connection
The Yamaha ECU Plug & Play Cable allows you to connect the Aim EVO4S Data Logger to the Yamaha-specific connector. The Yamaha ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Yamaha YZF R1M Motorcycle
Plug & Play Cable
The plug & play cable has been specifically designed for the following Yamaha motorcycle models and years:
  • Yamaha YZF-R1 (YEC included) – 2015-2019
  • Yamaha YZF-R1M (YEC included) – 2015-2019
  • Yamaha YZF-R6 – 2017-2020
Example Data Protocols
Example data protocols sampled can include RPM, gear, front wheel speed, rear wheel speed, brake pressure, throttle position, traction control, map selection and many more. Refer to the user guide in the Downloads tab for a full protocol list.
  • For Yamaha YZF-R1/R1M & YZF-R6 motorcycles only
  • Plug & play cable for the Aim EVO4S Data Logger
  • 712 7-pin male binder connector
SKU: YAM-1-PP-EVO
Part Number: V02585150
Yamaha YZF-R1/R1M/R6 brukerveiledning
