AiM Exhaust Gas Thermocouple Temperature Sensor M5 K Type Kart
SKU: S-T-EGT-K
- Normalna cena
- £70.00
- Normalna cena
- Cena sprzedaży
- £70.00
- Cena jednostkowa
- za
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.
Measure exhaust gas temperature | Thermocouple male fitting |
Wide temperature range |
Temperature range of 0-1000°C
Sensor cable length 25cm
- Temperature working range: 0-1000°C
- Cable sensor length: 25cm
- Cable Type: Compensated
- Two-pin male thermocouple connection
- K Type thermocouple
- AiM Exhaust Gas Thermocouple M5 Sensor (EGT)
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe.Key Features :
The AiM K Type thermocouple temperature sensor is fitted with a two pins male thermocouple connection.It can measure the exhaust gas temperature by being placed in the exhaust header pipe around 150mm from the exhaust pipe.
MyChron4/5 S 2T Sensors are connected to the dash using the single patch lead (supplied with the dash), which splits into 2. Spare sensors are advisable to have as a spare or to have fitted to a 2nd race engine.To use the sensors with an AiM MyChron expansion or EVO4 and EVO4S data loggers, you will need a 712 four-pin patch lead or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger. You will need a 712 three-pin patch lead.
