1 z 2
AiM SmartyCam 3 GP HD U Bolt Mount For Recording Box 2.1 & 2.2 & 3
SKU: SM-UB-GP-R
Normalna cena
£80.00
Normalna cena
Cena sprzedaży
£80.00
The SmartyCam 3 GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.
Ball & socket adjustment system
Suitable for 0.5 to 1.2" bar, roll cage, railing
SmartyCam GP HD 2.1 & 2.2 Compatible
SmartyCam 3 GP Compatible
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2 & 3. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.
The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2".
AiM SmartyCam GP HD U Bolt Mount For Recording Box
  • For use with SmartyCam GP HD 2.1 & 2.2 & 3
  • Arm height 90mm ( 3.54 inches )
  • U bolt
  • 90mm arm
  • Clamp base with ball
  • Mounting bracket
  • Locknuts
  • Washers and screws
Technical sheet Race Studio 3
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2 & 3. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches. The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport. The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
  • U bolt
  • 90mm arm
  • Mounting bracket
  • Locknuts
