AiM Water (Coolant) M5 Temperature Sensor with 712-719 3 Pin Patch Lead
SKU: S-T-M5-K-P
- Normalna cena
- £110.00
- Normalna cena
- Cena sprzedaży
- £110.00
- Cena jednostkowa
- za
AiM Water (Coolant) M5 Temperature Sensor Kart
The AiM M5 water temperature sensor for MyChron can measure and sample water temperature providing accurate readings. This sensor comes with a 712-719 3 pin patch lead.
M5 water temperature sensor | 4 pin 719 male binder connection |
Suitable for all MyChrons | Rotax, X30, OK Engines |
The AiM PT100 M5 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings.
The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables.
Temperature range of 0-150°C
Sensor cable length 250mm
The M10 thread is most commonly found on Rotax, X30 and OK engines
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead.
The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
- Temperature working range: 0/150°C
- Cable Sensor Length: 250mm
- M5 thread
- 4 pin male 719 Binder connection
- 712-719 3 pin patch lead
- AiM Water Temperature Sensor M5 Thermocouple Resister
The AiM M5 water temperature sensor for MyChron can measure and sample water temperature providing accurate readings. This sensor comes with a 712-719 3 pin patch lead.Key Features :
The AiM PT100 M5 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings. The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables. This sensor comes with a 712-719 3 pin patch lead.Temperature range of 0-150°C
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead. The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
- M5 thread
