4 Channel CAN Wireless Wheel Button Plate
£525
4 Channel Wireless Button Plate. Our 4 channel wireless system allows you to have push-button controls at your fingertips....
Features:
  • CAN Wireless System
  • 4 Push Button Controls
  • CR2 Lithium Battery
  • Free Race Studio 3 Download
CAN 4 Channel Wireless System.
Our AiM 4 channel wireless system allows you to have push-button controls at your fingertips. Whether you have a detachable steering wheel or would just like to avoid the need for an unreliable coiled wire connection from your steering wheel to the dash board.
The system uses a wireless (RF) connection between the wheel plate transmitter and CAN receiver; this compact receiver is neatly installed behind your dashboard and attached to your AiM CAN device directly using the supplied Binder harness.
Please Note: Steering Wheel NOT INCLUDED
4 Channel CAN Wireless Wheel Button System
Our 4 channel CAN wireless button system has four digital push buttons and transmitter which bolts straight to your steering wheel hub and fits all standard bolt patterns.
Our AiM CAN transmitter and wheel plate assembly bolts straight onto your steering wheel hub and fits all standard bolt patterns on 6 x 74mm, 6 x 70mm and 3 x 50.8mm PCD steering wheels. Supplied with a standard CRS Lithium battery, with a guarantee lifetime of 3 years or 50,000 miles road time. There is no need to worry about a flat battery with our smart system as the battery voltage is regularly transmitted to the CAN receiver and forwarded to your AiM device, giving you around 30 days notice if to needs to be replaced.
With unrivalled RF communications between transmitter and receiver, tested to withstand even the harshest EMI that can be generated within your car, so you will never lose connection with your wheel.
Use our PDM and Race Studio 3 Software to control the behaviour of the momentary push buttons to act as simple latching switches or more complex control.
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Product Video
Transmitter Components
  • Button Plate Front: Matt Black, Textured Acrylic
  • 176 x 154mm
  • Battery Housing: ABS-UL94-V0
  • 54 X 38 X 23mm external
  • CR2 3V Lithium
  • >2000 hours active use
  • Pushbuttons: IP67 momentary
  • Assembly: 4-channel: 220g 176 x 154 x 33mm
  • PCDs Supported: 6 x 70mm, 6 x 74mm, 3 x 50.8mm
  • AiM CAN Wireless Transmitter Assembly
  • Button Plate with 4 Pushbuttons & Covers
  • Battery
  • Decal Sheet
  • 4-Channel Receiver with Connection Harness
  • Installation Instructions
