Motorcycle 5 Button Handlebar Race Switch
Custom configured 5 button handlebar race switch.
Key Features:
This 5 button custom configuration switch has been designed for use on race & track bikes. With the standard ECU and where lights and turn signals are not needed. The aluminium assembly has been ergonomically designed for easy use and encompasses 5 sealed momentary switches which are black in colour and metal bezel. With rugged machine aluminium construction, and switches that are fully waterproof to provide greater crash protection and electrical integrity. As an example for your switches you could set the following controls, Map Switch (latching on/off
5 way left All buttons are black & metal bezel Common Ground 400mm DR25 All Momentary Ground N/O |
5 Button Handle bar Control Switches for Motorcycle
- 5 way all button
- Width at centre - 13.5mm
- Colour: Black
- Metal Bezel
- Common Ground
- 400mm DR25
- All switches are momentary N/O
- Black: Common Ground
- Switch Sealing: IP67
- Laser Engraved: 1 - 5
- Wire Colours are: 1 - Red, 2 - Green, 3 - White (no stripe), 4 - Blue, 5 - Yellow
- SP230 - BD-SW-5B
