Aim 14 Pin Strada 1.2 CAN Harness For MX Strada Series
SKU: MX-S-L-...
£160.00£192.00INC VAT - UK only
- £160.00
Aim 14 Pin Strada 1.2 CAN Harness For MXS, MXP, MXG
The Aim 14 pin CAN connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes | Replacement for original wiring |
14 pin AMP female connector | 4 pin binder 719 female |
5 pin binder 712 female | Compatible with cars & motocycles |
14 Pin AMP CAN Harness
The Aim 14 pin Strada 1.2 AMP connector with CAN connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity, a 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 5 cables.
These are some of the items that can be added to your vehicle for incrementing performance and data.
Aim 14 Pin Strada 1.2 CAN Harness for MXS, MXP, MXG
- 14 pin AMP connector flying connector
- 4 pins Binder 719 female connector
- 5 pins Binder 712 female connector
- X5 1 x 0.5 cables
- 14 pin Strada 1.2 CAN Harness
The Aim 14 pin CAN connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.Key Features :
The Aim 14 pin Strada 1.2 AMP connector with CAN connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays. It is ideal if you want to transfer your dash to a different vehicle or if your original harness has been damaged. With pre-wired connectors for easy connectivity, a 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 5 cables.
These are some of the items that can be added to your vehicle for incrementing performance and data. ![]() |
- X5 1 x 0.5 cables
