AiM Data Hub 2 CAN Inputs with External Power
The 2 CAN connection multiplier works as an interface between all our AiM loggers and the peripheral equipment.
Key Features:
Connection Example |
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
Two way Data Hub
- Dimensions: 70x30x23.5mm
- CAN cable length: 40cm
- Source cable length: 165cm
- Weight: 86g
- AiM Data Hub 2 CAN
