    Aim 712 Male & Female Binder Plugs - AimShop.com
    P-712
    Hurry, only 9 items left in stock!
    £16.00
    £16.00
    The Aim 712 binder connector is ideal if you need to replace a broken, damaged connector or you just want a refresh. The connectors are robust, reliable, and perfect if you are shortening, making custom length cables, or adding additional sensors or extension cables to your Aim system.
    Key Features:
    712 binder plug Male or female options
    Metal binder Strong & reliable
    Available in Male & Female 3,4,5 pins.
    Ideal for replacing broken plugs or when adding sensors to your Aim system.
    High-quality connectors designed for the rigours of Motorsport.
    • 712 Binder Plug available in:
    • Male - 3, 4, 5 pin
    • Female - 3, 4, 5 pin
    • X1 Aim 712 Binder Plug Male or Female
