AiM Car Brake Pedal Position Sensor Linear Travel Pot 10mm
£85.00
The AiM linear short stroke (10mm) displacement potentiometer for measuring brake pedal movement.
Key Features:
  • Brake position sensor
  • 4 pin
  • 10mm displacement
  • Free race studio 3 download
The linear short stroke (10mm) displacement potentiometer is ideal for measuring brake pedal movement. A pedal travel sensor such as this can be simpler to install in many vehicles than plumbing a pressure sensor in the brake line.
The compact sensor body measures just 3/4" (19) OD X 1 3/8" (35mm) long overall (less plunger). Two 1/4" (6mm) mounting holes are located 1.34" (34mm) centre to centre
Ideal for high precision data acquisition or control systems.
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. This makes ours amongst the best in the market place today.
Unlock your potential
    AiM Brake Pedal Position Sensor Linear Travel Pot 10mm
      Technical sheet
